MNtundraRet
Aug 14, 2013Navigator
If the battery "disconnect" switch is "Off" the converter/charger cannot charge the battery(s). They are out of the loop and the converter is supplying the 12v power. The alternator by-passes the "disconnect" and will charge the house-battery and chassis-battery whether the switch is "on" or "off".
Turn it on to get the battery(s) charged while plugged in. It is only used when stored without access to shore-power.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
