MNtundraRet
Aug 14, 2013Navigator
mena661 wrote:
Mark, that depends on the MH. My converter goes straight to the batteries. I can turn the disconnect switch off and charge the batteries (glad it's wired that way).
I take this to mean the converter/charger is wired to both the battery(s) and to the 12v circuit. Otherwise; neither the battery or converter would work if the "disconnect" solenoid (or solid-state isolator) failed and the battery(s) were disconnected. :B
My MH works as I stated. If the disconnect fails my converter will power the 12v circuit if I have shore-power. Since the house-batteries would be out of the loop, the generator could be used for a while but the h-b's it relies on would discharge without the charger connected. :(
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
