MNtundraRet
Aug 15, 2013Navigator
There is another method to the madness (or madness to the method?). :h
If your in the boonies, and run the generator for power, and you have a portable charger along, plug it into a MH 120v, ac, outlet. Now you could use it charge the house-batteries on "disconnect". Also; if the house-batteries were low the MH engine can be started with alternator charging house-batteries. It works with batteries on disconnect or not.
You could get by this way in the boonies, but generator needs to run for any power for both AC & DC. Fuel is expensive. :M
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
