While on a trip to South Texas recently, we were set up in a campground. On Saturday morning, we were watching one of 123 channels in the Houston area when all of a sudden, the TV started to act up. ...
They can die, but it's a fuse not a breaker.. Check your wall switch (the plate with the light and the switch) see if the light is on.
If you need to replace it, Consider a winegard Sensar IV with Sensar Pro to replace the wall plate.
If yuou need to replace JUST the wall plate, consider the Snesar Pro from Winmegard .. it will work with the jack and makes the "Sure Lock" look like.. Junk.
