02rexhallExplorerJun 06, 2015jack removalWhat should I know before attempting to remove the center hydraulic jack of my lippert level up system that is leaking. I have checked and it is not the fitting leaking. So i must take it off to have ...Show More
robatthelakeExplorerJun 06, 2015If You Pinch off the Hose with a pair of Vicegrip type pliers You will lose less Fluid!
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
Related ContentStaple RemovalEasy way to remove slide topper?Removing electric jacksTailgate RemovalAtwood Electric Jacks - Replacement Electronics
