rlw999
Sep 01, 2021Explorer
Gdetrailer wrote:rlw999 wrote:
They have a 2000W/2000Wh device for $2000 -- that's 160Ah@12V, so that's not insanely expensive when 200Ah of BattleBorn Lithium batteries cost $1800 (and that's just for the batteries, no charger, no inverter, etc that you get with the Jackery).
Losing 15% to power conversion losses is not terrible a $500 AIMS 2000W inverter has 10% loss at full power.
It's definitely not a generator, but it's not useless waste of money either if you want a decent amount of portable power that you can carry around with you.
Losing 15% (inverter loss)to get to 120V and then an additional 15% (Converter loss) to run 12V devices is 30% loss.
In your example of 160 Ahr at 12V that is a 48Ahr capacity loss giving you only 120 Ahr to use.
Makes using a BattleBorn battery direct a much better choice.
Man, times sure have changed when you can say "only 120Ah" when referring to RV batteries!
My RV still uses flooded lead acid batteries since I don't boondock enough to make it worth replacing them. And those 2 batteries combined only give me around 100Ah of usable capacity. Like I said in an earlier post, I have a unit similar to his Jackery and I use it to power a few things to help preserve battery life on the house batteries -- and I use that power pack for much more than RV'ing, and putting Lithium batteries in the RV won't help with those use cases.
He already owns the Jackery, so that's sunk cost, so he may as well use it even if he loses 30% due to conversion losses. 30% of $0 is still $0.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
