jornvango
Mar 19, 2022Explorer II
Jackery 500 versus my RV battery
My Casita trailer has one Duracell AGM group 27 battery with 92 amp hour capacity.
If I can use about 40% before needing to charge it, that's about 40 amp hours I can use.
I paid about $200 including tax.
Since I want to safely charge my laptop (90W 110V charger), I'm debating adding a Jackery 500. I like how it's portable so I can take it with me to use on the road in the car, away from the RV.
The Jackery 500 has 500 watt hours capacity. At 110V usage for my laptop charger, that 500 watt hours converts to 4.5 amp hours. Since it's lithium, that's 100% usable.
The Jackery 500 costs about $600 including tax.
Watt-hours = Amp-hours * Volts
Amp-hours = Watt-hours / Volts
Is the above correct? Does my $200 RV AGM battery give me 40 amp hours (or 4,400 watt hours at 110V) versus only 4.5 amp hours for the $600 Jackery?
If that's the case, I'm better off adding an inverter in my RV to charge the laptop. I can't believe the above is correct since the Jackery 500 would be too pricey for that small amount of power compared to a regular AGM battery...
I have a suspicion that my math is way off. :h
Thanks,!
Thanks,!
