philh's avatar
philh
Explorer II
Dec 30, 2021
Jacking up with MorRyde IS
I'm going to pull the tires off one by one to have TPMS installed. We are camping, so I'm not breaking down camp to drive to the tire dealer.
I'd prefer to lift each tire rather than lift the trailer frame, but not understanding the instructions in the service manual Located here Instructions are on page 4, and trying to understand It is permissible to jack up a unit equipped with a MORryde Independent Rubber Suspension System only on the Beam Assembly under the Rubber Springs" That appears to be on an angle, so how would I use a bottle jack to raise the wheel?
Trying to raise the wheel as opposed to lifting the whole frame up on one side.
  • CA Traveler wrote:
    Those are very nice blocks. For a different application I made these. My blocks are 1’x1’x2”, 1 1/4” (ie 1.25") sub floor plywood and 3/4” plywood glued (Gorilla glue) and screwed together. The cut corners eliminate the sharper square corners. They can be stacked as needed. The rope loop makes them easy to retrieve with any pole and to carry. They are also useful for securing picnic table covers, mats, etc. in windy conditions.
    Nice! Smart move on using plywood as it doesn’t split.
  • Cummins12V98 wrote:
    I did make them. They are 3/4" AC solid core plywood glued with Permatex PL3 and screwed. There are no internal supports even with 17,500# setting on the four. The front boxed are longer and do have a pc of 3/4" plywood mid way vertical. They are holding up well with 6 years of full-time use.
    I cut all the pcs from one pc of plywood.
    I made what Ron has made for the TT we bought and sold and one reason was for jacking the TT if needed as the frame was very high. Also for electric jack. chevman
    Very nice.
    Not sure how I would store them. I'm already over GVWR in the trailer, and don't have a lot of free space. Could see about making room in the truck bed.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
