in5r
Sep 03, 2013Explorer
I had the same exact problem with a 30' Jayco Eagle TT we had. Ours was on the front wall, same issue. It is all in the way they frame up the bed support. When the struts are compressed it pushes on the wood work and thru the wall. On mine I strengthened up the plywood between the wall and where the hinges fastened. and added some gussets to the inside 1 x framework as well. That was the easy part. The more challenging part was removing the exterior moulding to pop the metal off and get the frame work of the trailer back where it belongs. Hope this gives some insight. Slight possibility you can get the bow pulled back from the inside without taking the metal off.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
