2oldman
May 27, 2015Explorer II
You could leave the batteries where they are and minimize line loss by getting 2-12v batteries, and running them in series @ 24v. Then of course you'll need a 24v inverter, which are not hard to find.
If you want the inverter in the battery box, which is never recommended, it's best to get AGM batteries to not eliminate, but severely limit any outgassing.
I doubt you'd forget to turn off the converter as long as you look at your system voltmeter now and then. It would be telling you quickly that your battery voltage is dropping, fast.
Solar panels can also be connected in series to up the voltage to limit line loss.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
