Baja_Man
Aug 28, 2020Explorer
I had a similar leak at the plastic fitting to tank connection. PO thought the hex nut looking plastic head of fitting could actually be tightened to connected water shut off valve! It is a hex head but can not, and should not, be turned. Spin welding was used to install it from tank manufacturer.
How I repaired:
I purchased THIS welding kit. I welded it using the plastic pieces included in the welding kit. This was repair was made over 8 mos ago and hasn't leaked a drop. Simple, on the cheap, and has worked flawlessly.
How I repaired:
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
