OpenRangePullen
Jul 20, 2013Explorer
Its a Jensen what did you expect. If your replacing it like I and many others did already anythings better than A Jensen. If your replacing it once its out use a small crowbar and pry off the front plastic cover then pry open the disc bay, but becareful then use some needle nose pliers and pull out the Cd's from the very edge so you dont damage or scratch it.
Good Luck:)
Good Luck:)
