CincyGus's avatar
CincyGus
Explorer II
Jul 20, 2013
Jensen Radio/DVD/MP3 player
If you have one of the Jenson Square faced Stereo/DVD/MP3 players installed in your rig and it happens to fail to light up, there is a 15amp flat fuse in the back of it that may be the cause. I shorted mine out by brushing the positive cable of my battery against the diamond plate on the front of the trailer while rerouting the battery cables.
Checked all the fuses in the fuse box, scratched my head and then thought I remembered seeing somewhere the radios were fused on the back side.
Pull the trim cover off gently that is around the outside edge.
Remove the 4 screws in the corners and slide the radio forward.
Look on the back side and replace the fuse.
hit your power button to make sure you have fixed the issue.
Double check your connections in the wiring harness to make sure nothing wiggled free with all the movement and replace and screw back in. Replace the trim and your good to go.
Took less than 15 minutes.
Just FYI in case someone else has a similar bonehead move they need to correct ;-)
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
