ScottnSherrie's avatar
Nov 10, 2013
John Deere chassis brake reference
For those few lucky souls that have a motor home built on a JD chassis, I have found another vehicle you can reference for brakes, at least the calipers and pads.
The 1994 Ford F-700 front brakes are the same dual 2.5 inch piston Dayton calipers. The sites I found list both the 2.5 and 2.88 inch inch calipers so be sure to select the right ones.
The above post is based on the assumption that all JD RV chassis have the same configuration as mine with identical disc brakes on all four wheels.
Your results may vary. Statements have not been approved by the FDA. Not valid in Puerto Rico or Hawaii.
1 Reply
  • j-d's avatar
    j-d
    Explorer II
    Good on YOU for finding the equivalent common parts. I was pretty sure that'd be the case, at least for rebuild kits. You found the whole caliper. Even better! Congrats!
