stripit
Jun 07, 2016Explorer
I helped install a set of JT Strongarms on a 36 ft Mobile Suites 5th wheel for a friend. Night and day difference in the stability of their coach. I would say almost rock solid. I was at an rv show and bought a set of Winfield Arms Here
and installed them on my 36 ft Mobile Suites 5th wheel, could not tell any difference in the two companies as far as stability went. Winfield was a bit less expensive and easy to install. Night and day difference in how the rig felt before being stabilized and after. I think they all do the same type of stablizing, some easier to work that others, but you will be very happy with which every system you purchase. I also used my Roto-Choks between the tires in conjunction with the stabilizing arms.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
