landyacht318
May 11, 2015Explorer
The T-1275 is listed at 82Lbs, not 84 as I originally posted, I will edit the OP.
I found the SCS225 and the T-1275 both cost 175$ at my nearest distributor with the t-1275 having a 3$ higher core charge
I do have nearly 200 watts of solar, and the screwy31(USbattery) which is about to fail, has about 465 cycles on it, in 19 months. I do not think this is bad. In terms of cycles per dollar the screwy31 has been a better value than all previous batteries, but it also got much more attention and massaging.
However the screwy31 recharging requirements are rather extreme. If it is not top charged daily at high voltages, upto 15.3v, Specific gravity tanks quickly and performance, (voltage held under load) is horrible. And EQ cycles are required every 2 to 3 weeks even when top charging daily.
I'm hoping Trojan's are less demanding in this respect. Mex in the past has called flooded 31's acid starved. Trojan's 31 weighs 2 lbs more than USbattery's 31, so perhaps Trojan's 31 would still be petulant.
Fitting a T-1275 where the screwy31 currently resides is going to be a very tight fit. The screwy31 barely fits. The tray can be lowered with more effort than most would employ to achieve, but the tray is currently compromised and needs attention anyway.
My main curiosity in this thread is the plate thickness, if it can be determined by weight. Trojan lists CCA ratings for its 24/27/31 group sizes but does not bother with CCA ratings on the t-1275.
SCS, superior cycling series, in comparison to what, standard dual purpose marine batteries? That is not such a high bar to jump over.
I'm hoping the T1275 is on another level compared to the 24/27/31 group sizes. As the price is the same, I'd be a fool to not try and fit the T-1275 instead of another 31 compromise.
This is an interesting link.
http://www.pbase.com/mainecruising/deep_cycle_battery
The t-1275 is also called a J150 but this model has different handles. that extend beyond the case where the t-1275 does not.
He calls the 24/27/31 'pseudo deep cycles" at 600 LAB cycles to 50% DOD
He says both the t-105, J150 are rated at 1200 Lab cycles to 50% DOD
Same price but 50% more rated LAB cycles? Sign me up.
Bottom line is, I want a true deep cycle battery, and I do not think that is possible in a 12v format in the 24/27/31 size, no matter the labelling on the battery. I will go through the effort of fitting the T-1275, even though shaving off a handle of an SCS 225 would be easier.
USbattery31 and trojan's 31 might very well be superior to any other flooded group31 available that has a 'deep cycle' claim, but can they compare to a battery that was designed around cycling in the first place?
Does the weight/AH ratio of the T-1275 place it firmly in the true deep cycle camp like the t-105, or is it somewhere in between T-105 and the SCS 24/27/31?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
