tenbear
Oct 25, 2016Explorer
The reason for using large wire for the battery connections is to reduce the voltage drop. Since the jumper wire is usually much shorter than the others, a smaller wire will have a much smaller voltage drop than the other wires so it's size is less important than the longer wires.
Of course, all the wires must have a current carrying capacity adequate for the highest current the batteries will see, either charging or discharging.
