StirCrazy
Feb 27, 2021Moderator
BFL13 wrote:
In the OP the salesman was asked if the solar kept charging with the batteries turned off (meaning ? disconnected? ) and he said no--correct!
Then the OP said with the "coach turned off" -- Now it is all the salesman's fault! :)
I think they ment with the battery disconect switch turned off. which would be the wrong way to install the solar as you always must disconect the pannels first or you risk screwing up your controler.
I have the go power on my 5th wheel now and I have to open everything up and see how they put it on so I know if there is a pannel disconect or not. if there isnt I have to cover the pannels before I disconect the batteries.
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
