SCOMP225
May 23, 2013Explorer
I've had my Hot Rod for over 12 years and it works great and it will produce hot water in 30 to 45 min or so and save all that gas.
You should install the T-Stat in the middle of the tank for best results, I just leave mine plugged in and use the switch I have to turn it on. My T-Stat is set at 125 deg which is plenty.
One additional note : I do not have it on if I'm on inverter, it does draw amps.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
