eric1514
May 24, 2013Explorer
Here's a pic of the thermostat I mounted to the rear of my water heater. This side is accessible under the sofa in my coach. You can see that I had to cut away a small chunk of the white foam insulation for it to fit flush against the metal tank.
This is also Camco's version of the "Hott Rod" I think it works great.
Good Luck,
Eric
Good Luck,
Eric
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
