westend
Aug 04, 2013Explorer
You will need a charge controller between the panel and the batteries but it does not have to be MPPT unless you choose a solar module that is nominally 24 volts. All 12 volt nominal modules can be controlled with a PWM charge controller which is less expensive.
Read here: Jack and Dan Meyer's Golden Rules
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
