Almot
Aug 05, 2013Explorer III
mitch5252 wrote:
OP here again. I think I should have been more specific in describing my situation.
I tow a small (16') travel trailer with a Toyota Sienna van (2006). Weight is an issue (the rig's weight, not mine (although that could be a different discussion in a different category...))
I plan to boondock for several months this coming winter in Mexico (Baja)
I have a Honda EU1000i generator.
I plan to carry a 2-gallon gas can for the generator.
I have a single Group 27 battery and LED lights.
My SOLAR GOAL (:@ ) is to cut back on the Honda usage (to save gas due to unknown gas availability in Baja without having to drive many miles) and be able to watch an occasional DVD and charge my iPad.
There is - usually - no problem with gas in Baja. Any place with fresh water will have Pemex gas station not too far. There is a problem with propane, though. Pemex don't sell or refill small tanks.
About your Solar Goal. It sounds like you don't have much roof real estate. Roof-mounted or portable - depends on the length of stay and location. In some places your free-standing panel might disappear after going out to town for a big fiesta, despite being on a camp with some other gringos around. Getting it in and out of the trailer every day, setting up and hooking up can get annoying.
If you decide to go roof-mounted, max up the available space and get at least 2*100. Led lights will need 15 AH a day or less. Ipod or Ipad? Tablet can be more than 15 Ah, depends on daily hours of run and the task. DVD? Played through what - 12" tablet or 36" LED TV? Roughly, all these toys can take 15-30 Ah a day with moderate use. So you are at 30-60 AH a day, roughly. To collect 60 AH with flat panel in winter, you need 400W total panel wattage. Same 60 AH with tilted panel oriented South (not tracking, just tilted South at 40 degrees) will require 200-240W. If you play with toys less, then 300W flat or 150-180W tilted. Or smaller yet - this really depends on your lifestyle. This is what you need to avoid running a generator at all, though you might want to add another Gr27 battery. Having said this, - any panel will cut down on generator time.
Having a tilted roof mount, when you move from one location to another, means - 4 axis tilt, this is too much trouble, IMO. Check the List of completed solar projects - some people have accomplished this (or tried to). There is no off the shelf solution. Same List shows how to flat mount - L-brackets bolted to the panel sides are the most common solution. You drive tapping screws into the roof if it's plywood, or use well nuts if it's fiberglass.
Portable - I don't think this will work well in Baja. Theft is one thing, wind is another. Tie it to step ladder, and it will flip over. Make a heavy frame of 2x2 boards, and it won't be portable.
Have fun.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
