Tom_M1
Aug 09, 2013Explorer
The panels are mounted using 1 x 2 1/2 in. aluminum rectangular tubing that is screwed to the fiberglass wall using 5 stainless sheet metal screws and silicone adhesive. Here's some more pix:
Lower pin is an aircraft locking pin that I acquired at a swap meet. 2 per panel.
Upper pin is stainless steel bolt with head cut off
Upper pin drops into slot on top of rail
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
