Almot
Aug 10, 2013Explorer III
mitch5252 wrote:
... if there is a certain size wire I should use between the panel and the controller, and the controller and the battery, based on panel size?
Yes. This is what I was saying a few days ago.
1) Controller-battery booster cable (the one with crocodiles) should be gauge 8 or better, if you want the distance 20ft or more.
2) Panel-controller MC4 cable gauge is not important - they only come in #10 or #12. In your case #12 is fine, but #10 is better for possible future upgrades. This is - if the "distance" is less than, say, 40 or 50ft (which means 80-100ft total length of 2 leads). If you want it farther than 50ft, then definitely go for #10, or even custom-made #8.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
