pianotuna
Aug 10, 2013Nomad III
Hi Mitch,
There is no need to disconnect the controller from the battery bank. You could have a switch (I do).
So you will only need two clips (may I suggest insulated ones?) But it seems to me a two pin connector would be even better than clips. (similar to the four pin connectors for a trailer?)
There are water proof connection boxes you could use as well.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
