xzyHollyxyz
Aug 10, 2013Explorer
If I don't disconnect from the battery, then the wires will be sticking out of my storage compartment, unless I find the cajones to drill a hole in the storage compartment floor! :)
I'm going to Google image search a 2-pin connector...........
Okay, I get it. Now, do they make those things in "sizes" so the 12 gauge wire will fit?
Dang, now that I'm not discouraged, this is getting exciting! And fun.
pianotuna wrote:
Hi Mitch,
There is no need to disconnect the controller from the battery bank. You could have a switch (I do).
So you will only need two clips (may I suggest insulated ones?) But it seems to me a two pin connector would be even better than clips. (such as the four pin connectors for a trailer?)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
