Tom_M1
Aug 11, 2013Explorer
I used Anderson PowerPole SB50 connectors. They are robust, foolproof, and cheap (on eBay). I crimped the contacts on mine but soldering is okay also. It doesn't matter what color connector you use but they all must be the same color. Each color is keyed differently so one color won't mate with a different color. There is a standard color code where each color represents a certain voltage. Yellow typically represents 12 volt.
Here's some more pix:
[img]http://i1095.photobucket.com/albums/i468/tomzpix/Solar/CableEnd_zps93a750f2.jpg?t=1376230282[/imp]
SB50 connector on end of extension cable.
Extension cable.
Junction box and wire coming through wall of coach.
Junction box.
Doubled up SB50 connectors.
Extension cable.
Junction box.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
