Olli's avatar
Olli
K-Z 16BH Brake Question
Problem description. I was working on getting my trailer ready for summer and when doing some test driving, I noticed that my brakes stick after braking. They don't lock, but are definitely sticking. It's worse when I use manual override to apply trailer brakes only. The brakes come un-stuck after rolling back on reverse even for few inches.
Question. So what do you guys think, is this simple "disassemble-clean/lube-reassemble" type gig or does it sound like needing new brakes? The controller (Tekonsha Prodigy RF) appears to be working well and changing the boost makes a noticeable difference, but if I want to adjust the boost high enough to grab trailer brakes, the sticking will occur. The problem may not be that bad on the road as after a brief test drive around couple of blocks getting up to 40 mph and stopping for stop-signs, the brake drums were warm to touch but not hot as I anticipated.
Also, I was pleasantly surprised by my Kia Sorento. On my slow test drive, the car towed the trailer beautifully. I wasn't loaded to the hilt, so a "full load test" is still in my plan before heading out for a real trip.
Also, I was thinking about buying new brakes just in case as driving to any trailer shop from where the trailer is stored is a bit of a trip, so do you have any recommendations on the brake assemblies?
1 Reply
  • First adjust the brakes. If that doesn't work, start pulling drums to see what is going on.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 12, 2026
