DryCamper11
Nov 08, 2013Explorer
MEXICOWANDERER wrote:
Ya might otter want to read a technical data sheet regarding the quiescent draw of a battery separator seƱor pianotuna
Pianotuna's point, as I took it, was that the OP was considering using a switch operated continuous duty solenoid (not a normal battery isolator). The OP seemed to want it set up so the solenoid was not powered from the ignition, and he wanted to leave it continuously on so that he wouldn't forget to turn it on.
In that configuration, I agree with pianotuna: 1) there would be a continuous parasitic draw to power the solenoid and 2) you'd run down the engine battery with the RV battery, potentially leaving you stranded.
If I misunderstood the OP's plan, or pianotuna's comments, I apologize.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
