DryCamper11
Nov 08, 2013Explorer
truepath wrote:
I've decided instead to use a SurePower 1315 bi-directional "smart" solenoid.
Does anyone know if this allows the RV batteries to assist during engine starting?
I note it's rated for 100A, which seems low for starting current. It also seems to have an optional override to engage by manual switch, if desired. Is it designed to carry starting current loads when activated with that switch? I assume it's not enabled during starting by default as the alternator won't be producing much voltage until the engine is running. I use my manually activated switch as a normal starting boost switch.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
