greatwines's avatar
greatwines
kge kipor 3500 ti generator
We need some help replacing the fuel filter on our kge kipor 3500 ti generator. Where is the fuel filter located. We do not see it right in front when the door is open. How so you get to it?
Thank you in advance for your help
  • The filter is a tiny little cylinder approximately 1.5 inches long, 3/8 inches wide standing on end attached to the fuel valve, drain tank, remove fuel valve
  • Manual states in section 3-6 that it is above the fuel switch and in the gas tank. You have to drain all fuel to remove it.
  • What does the manual say? It may be in the gas tank.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 05, 2025
