TomG2
May 07, 2018Explorer
Killer Amps
I want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
wa8yxm wrote:
at this battery size I ahve to ask if it's a AGM or liquid. (LIquid would be like a garden tractor battery or motor cycle, though if I had a cycle that is one place I'd use AGM)
I woudl say try it. draw your 10 amps for an hour (10 amp horus) let it sit for like 20 mintues and measure voltage.. If it's too low add more battery
if it's still at say 70% recharge
NOTE: for batteries other than DEEP CYCLE 70% is too low. DEEP CYCLE (Golf car mostly) can go to 50%, but Starting batteries and MARINE/Deep cycle should never drop below 75-85% depending on the battery so you are likely doing damage .
You can also google the Effect (purket? Someone mentioned it above) and find some calculators that may help you find your discharge level.
