TomG2
May 08, 2018Explorer
Killer Amps
I want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
valhalla360 wrote:
What are you trying to accomplish? Might be easier to simply add a 2nd battery.
TomG2 wrote:
Run a 100 watt heater off an inverter. my inverter has a low voltage shut off, so I might give it a try. Only out $70 if it won't I can get the 100 ah battery that I really need.
Run a 100 watt heater off an inverter. my inverter has a low voltage shut off, so I might give it a try. Only out $70 if it won't then I can get the 100 ah battery that I really need.
