TomG2
May 08, 2018Explorer
Killer Amps
I want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
Tom_M wrote:My old TV heater core started leaking so I bypassed it. Now no heat. I bought one of these at a truck stop to heat my cab while driving to work. I placed it on the floorboard to blow on my feet. I could feel it on my feet but after a 40 minute drive it did not heat up the cab one degree. Granted, it was about 40 degrees outside, moving vehicle, heat leaks, etc..
I think a better option would be to buy a 12 volt heater. They are typically 150 watt. A search on Amazon found these:
12 volt heaters on Amazon
TomG2 wrote:
A Camper Shell, for those who do not know about them, is simply a fiberglass shell that fits over the bed of a pickup. Mine creates a box approximately 6.5' X 5' X 4' which can easily be warmed with any kind of small heater.
TomG2 wrote:How did it fail? The battery fell flat or lacked enough heat output?
The experiment failed, "Nothing ventured, nothing learned".
Some may be missing the whole point of camper shell campingI 'camper shell' camped years ago down in Mexico quite often. We had a blast.
pianotuna wrote:
...snip.....
To run the heater for one our a 100 amp-hour flooded battery would be a good fit.
