TomG2
May 08, 2018Explorer
Killer Amps
I want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
valhalla360 wrote:
Truckers aren't using resistance heat from lead-acid batteries.
TomG2 wrote:time2roll wrote:
Resistance heat from a lead-acid battery is a fools errand.
You need propane.
Are you calling America's truck drivers fools? Many use resistance heating in one form or another to heat everything from coffee to truck seats. I have a propane heater for cold weather. This test was to see if I could get a little heat for a short amount of time from my battery. Too much load and too little battery was what I discovered.
pianotuna wrote:
I did not say the battery should be inside the "cap". In fact, I would never recommend that unless the jar were in a sealed box vented to the great outdoors.
You need propane.
TomG2 wrote:
Not sure that I want to charge and discharge a flooded cell battery in the small confines of a camper shell. Good idea?
pianotuna wrote:
...snip.....
To run the heater for one our a 100 amp-hour flooded battery would be a good fit.
2112 wrote:
How did it fail? The battery fell flat or lacked enough heat output?
