RoyB
Jan 30, 2015Explorer III
Installation was easy for me - takes a couple of minutes... Pull the two bolts at the bottom of the BATWING antenna. Be sure to use the same orientation as shown here- otherwise the Jack antenna will not be level when raised up.
When done it looked like this google image. The front of the JACK antenna will be to the left of this photo.
My KING ANTENNA worked just fine with the same COAX CABLES and the Antenna Wall Panel 12VDC Power Source. Just push in the panel button to send 12VDC control voltage up to the KING antenna. I did not use the King provided DC POWER Insertion adapter.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
