davidceder's avatar
davidceder
Kinro Window latch
Has anyone ever replaced one of these latches on their RV window? The window is made by Kinro which I think was acquired by Lippert Industries. Any info on how to proceed would be appreciated.
http://www.pellandent.com/Motorhome_Product_Details.aspx?ProductID=6914&Return=302
1 Reply
  • I'm not familiar with that particular Bramd so my comments may not help you. That said most of the Window Latches that I have encountered in RV s have been made of Plastic,and are prone to being snapped off when closing .
    If this is the case just drill out the usual rivet and replace the latch with a piece of metal that can be drilled and attached with a Nut and Bolt or if You prefer a decent sized Rivet. It doesn't take an expert machinist to see that the Original Plastic part was just something that pivoted into a slot in the window frame. You may not end up with a fancy handle on the latch ,but you will have a latch that keeps the window closed!
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
