dougrainer
Sep 06, 2013Nomad
hershey wrote:
I have said before that I would like to have my sink drain into my black tank, but:
I would have some reservations about the possibility of the smell baking up thru the sink drain??? I know there is a trap but travel motion can cause that trap to fail. Could that be a problem or am I nit-pickin'?
You worry too much:B IF the travel motion "could" cause the P trap to empty (it does NOT), then there would be thousands of motorhomes/trailers with horrible smells in them. One thing I CANNOT get my customers to understand is this---GRAY tanks smell 10 times worse than Black tanks. Almost ALL tank odor problems in an RV come from a Gray tank issue, NOT the Black Tank. Most RV'ers use Black tank Chemicals. THAT breaks down the Black content and also masks any odors. Don't use a chemical and everytime you flush you get that "outhouse" type odor coming back up. IF you do NOT smell anything bad at your toilet when you open the flush valve, then the odds are, if you have a tank odor in your RV, it is coming from the Gray tank. YES, if any P trap or mechanical vent in the RV fails, then you will get a horrible gray odor inside the RV in transit. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
