campingwiththor
May 06, 2018Explorer
Thank u. Got the input water lines off...
Major problem now is ...the O thread nuts
are almost un reachable... let alone get enough
force to un tighten... Is there a tool one can
Purchase designed to turn these O Threds?
Thank u
Thank u
DutchmenSport wrote:
RV faucets are installed exactly like in your house. Remove the faucet and replace with a new one. Lowes, Home Depot, ACE hardware, any plumbing store, normal household style faucet will work. They are threaded 1/2 inch, same as the Pex plumbing in your camper. So, should be an easy replacement.
Faucets are usually held in place with a simple O threaded ring that tightens up on the bottom side of the counter top. Easy to remove, if you can reach it. That's the problem with RV sinks.... trying to reach it from underneath.
Just replace the faucet. Find a nicer one at any big hardware box store.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
