CA_Traveler
May 06, 2018Explorer III
My cabinet inside panels were glued and pin nailed but came right out. I now have completely hidden wire runs covered by screwed in panels.
Or if a inside panel won't come out then cut it out and cover it over when done.
Maybe this will give you access. Just a thought.
And I had to remove some panels to gain access to the kitchen faucet. The next step would have been to remove some of the 1x2 wood supports. Even when cut they are easy to replace using a sister board or metal bracing.
Aren't RVs fun?
Aren't RVs fun?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
