Gjac
Sep 09, 2021Explorer III
bgum wrote:Put a plastic straw into spark plug holes and pistons are defiantly moving up and down. Also put a cap full of oil in cylinder and compression only came up slightly may be to 15 psi.
Did you pull the plugs to see if the pistons are moving up and down as they should? I know you said they were dry but did you check the pistons?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
