Gjac
Sep 10, 2021Explorer III
allbrandauto wrote:What I did is check the compression on my lawn mower and got 65 psi so I know the gauge is good. Yes is spins really fast and can feel a slight pressure when I put my finger over the spark plug hole. In addition when I remove the air cleaner I feel no suction on the intake, instead it blows air out of the intake.
how do you know the compression gauge is good when you crank it over with the plus in it does it sound like its cranking realy fast take a plug out and put your finger in the spark plug port and bump it over than you will know
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
