Rigdon
Sep 16, 2021Explorer
if the intake valve had pressure coming out instead of in then you have stuck intake valves on both cylinders. the trick with pressurizing the cylinder through the sparkplug works very well. Other small engines used to get carbon fouling in the valve guides resulting in stuck valves and no compression usually from the carb running rich.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
