Gdetrailer
Sep 18, 2021Explorer III
enblethen wrote:
If it has compression release like on Briggs, you have to turn back the crank a little to get valves to close. When engine RPM is high enough the compression release disengages.
Not sure if Kohler has a compression release.
Found a parts diagram for a Magnum M20 HERE
Don't see any thing in the valve train that looks like any form of compression release which I would not be too shocked about. Kohler often didn't use compression release at least with the 1960s cast iron engines I have played with.
Sadly, I suspect OP may need open up and dissect the engine, kind of doubt this is going to be fixable via external means.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
