dougrainer
Apr 10, 2016Nomad
Replace the Door Magnet switch. Some use a PIN switch and no magnet. BUT, that is the FIRST place to start. The ONLY reason a step would attempt to deploy with the engine running(the ignition override should be engaged), is because the Door pin/magnetic switch is telling the step to deploy. Also, engage the DEADbolt lock on the entry door and then try to open the door. It will attempt to open about 1/4 inch until the Deadbolt stops it. IF the step tries or does extend, then the Door pin/magnetic switch is not adjusted correctly. The Step if the system I installed correctly will usually start to retract when the entry door is about 1 inch from fully closed. If the batteries were discharged, then there would be no power to operate the steps. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
