klutchdust
Nov 21, 2018Explorer II
Doug
To check fuses I use continuity between each exposed pin on the fuse, I do not remove and visually inspect each one.
Michael,
That may be the case with mine. I can get it to operate using jumper wires. On to another adventure then will check it out when I return.
Michael,
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
