klutchdust
Dec 12, 2018Explorer II
pauldub wrote:
It can be very helpful to download the wiring diagrams from the Winnie webside. My '03 Winnie has a circuit breaker for the step power and it's located in a storage bay. Your's may be similar.
Yes, thanks Paul. Yesterday i tested my incoming wiring and have no ground on the brown wire, that is coming off a magnetic door switch from under the coach, anxious to get under there today to check that out.
i found the panel you speak of AND if you remove the cover there are two fuses coming off the solenoids mounted back there. That was interesting.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
