Yaj
Sep 17, 2013Explorer
I just finished reinforcing ours.
Pull up the carpet, then the wood under that and you'll get to the bolt heads. I had to cut off the bolt heads (they used the rounded kind with the square shank, but they but it in a round washer) they would just spin. I did the closest ones first than the back ones so I didn't have to remove the steps
Anyway once I removed the bolts I replaced them with regular bolts and used a 1/4 X 2 inch steel bar the full width of the step for support. I had to relieve the wood where the bolt heads are for clearance. I put the closest support bar on top of the wood (inside the MH) and the back support bar under the wood above the step mount (under the MH). I also pored some thin, slow set epoxy along the edges of the wood to firm it up and keep it from creaking. They are nice and level now, with no creaks.
Good luck!
Good luck!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
