pianotunaNomad IIIMay 20, 2015L-16 AGMHi, I have a space problem. Will two AGM six volt jars fit in the same space as three Group 29 flooded cells? The AGM could lay on their sides.
ChandalenExplorerMay 21, 2015903 L16-AGM M8/DT/LT Length 11.66 width 6.94 height 16.41 weight 115 The 20 amp rate is 370.Having two to make 12v gives you... 370 amps.Where did the 550 come from?Nice batteries, but they are very tall and heavy.A group 29 is ~length 13, width 6.75, height 10I think the width might stop the batteries from fitting.. its close.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
Related Content16 Navigator L towing Jayco 24BHAGM batteryInverter AGM questionsMy AGM to Lithium conversionAGM batteries?
