pianotunaNomad IIIMay 20, 2015L-16 AGMHi, I have a space problem. Will two AGM six volt jars fit in the same space as three Group 29 flooded cells? The AGM could lay on their sides.
pianotunaNomad IIIMay 27, 2015I did get a thickness on the plates for the group 31 stuffed into a group 27 case. It is 3 mm (0.118 thousandths)The Surrette is 3.683 mm (0.145 thousandths)
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
Related Content16 Navigator L towing Jayco 24BHAGM batteryInverter AGM questionsMy AGM to Lithium conversionAGM batteries?
